BlackfireTotal Polish & Seal & Fuzion
RBJR
Greetings All:
Here is my project. I have a dark green metallic paint finish. Very deep in color with ton's of flake. It's been sitting for a while (3months) in the garage with a car cover over it. Been to busy with work, house and raising a year old grand child to drive the car and have to set aside the time to clean it.
Taking care of the car is my little get away so I decided this weekend to remove the car cover, wipe it down and hit the road. After removing the cover I noticed some scratches, light as they may be in a few areas. My goal is to remove the scratches with what I'm hoping is a simple process and still maintain the shine.
Paint is other wise in very good condition. Someone suggested using Blackfire Total Polish & Seal and top it off with Fuzion. I am looking for an approach that can be applied by hand, remove/cover up the the light scratches and make the flake pop.
Your thoughts and suggestions would be greatly appreciated.
Thanks,
Ray
Greetings All:
Thanks,
Ray
You can apply TPnS by hand. Use very little and work it in by hand until you can't see it. Try it on a white LC hand applicator. If that doesn't remove the scratches, try it on an orange LC hand applicator. If that still doesn't do it, I would try Meguiars Ultimate Compound on the orange hand applicator. If that does the trick, then TPnS on top of that with the white hand applicator. I haven't used Fuzion but assume that is some type of sealant? I use Blackfire Crystal Seal as my sealant and it seems to be pretty durable so far.
