LSNAutoDetailing
Active member
- Jun 21, 2014
- 3,373
- 21
I noticed that the inter-flex pads either fall apart, for fly off the BOSS tool while in use. The heat build up essentially melts the hook/loop that keeps it attached to the tool.
I'm guessing the only work around is to do one panel, change the interflex pad, and do one panel at a time rotating the Intrflex pads.
Is anyone else seeing this issue, and is that how you work-around the issue?
