BOSS pads vs B&S Low Pro
@nothingface. So you wouldn't agree with the above statement by WRAPT?
Sent from my iPhone
first part of his statement..no, second part yes
they cut and finish well, just stiffer then the boss...i'll take a lil stiffer pad for more pad durability. they're also cheaper
The BnS Low Pro pads are thicker overall, but the actual foam part is the same thickness as the BOSS pads. The added thickness is the neoprene foam part. That is pretty stiff and I don't think it is absorbing the movement of the pad at all like everyone is assuming happens with something like a LC CCS pad that actually has the thick foam.
I really like both of these pads. I don't even consider buying RUPES pads anymore.
I have not given the LC ThinPro pads a try yet. That is a pad that looks truly universal regards to working well on all the polishers.
