dpk20x
Member
- Mar 28, 2012
- 748
I have a small steamer from Vapamore and it looks like yours so they may be made by the same manufacturer. It works fine but I only clean my own vehicles. I'm wondering if your unit is heating up properly. The steam from these units will burn you and if you take the cap off too soon to drain the remaining water out the machine it will blow the cap right to the ceiling due to the pressure within the tiny boiler. It takes a long time for mine to run out of steam. I've used it to remove a stain from the cloth seat of a Dodge pickup along with an interior cleaner and I have used it to touch up some areas in the engine compartment. Can you test how hot the steam/water is?
I'm not the OP but I've noticed my Mytee doesn't seem to get as hot as my Mcculloch 1275. It gets hot but not as much as I expected.
