moves from a paste to an almost talc powder type consistentcy. Its often called flashing cause it essentially changes in a flash.
Some polishes with move to the talc powder type consistency. Others when worked will just turn clear and be barely noticeable on the paint and then move to that talc powder type consistency depending on the temp. humidity, etc.
What polish are you using?
I too was using Megs 3 step Deep Crystal System up to when I purchased the Flex 3401.Not sure, what would you recommend? It's a first for me in about 15 years. I had a sears polisher that I trashed. I spent 2 weekends a year since doing the hand applied 3 part meguiar's deep crystal system. Seems I'll need to get some halogen lamp setup also. I want to do it right.
Ah, thanks. Thought you were Hungarian, because Gerencs is a Hungarian name too.
Back to the original question. Breaking down means that the diminishing abrasives in a polish reach their final, extremely fine state, and they practically disappear. Their size is getting smaller and smaller, and after they performed the initial cut (while being in their original size), they break down into finer particles and do the final fine polishing of the surface, giving high gloss and great clarity. Heavier products, such as compounds usually contain macro abrasives (gritty feel between fingers), while other types, such as finer polishes contain micro abrasives (lotion-like). The abrasives (grit) are 'agglomerates' which break down to smaller, finer particles 'primary crystals' as they work. This can happen mechanically and/or temp-sensitively.
As you watch the trace of the polish, you can see that it gets finer as you progress with the procedure. When the polish is so fine that it is almost translucent, opaque - because the particles in it are now ever soooo small - this is the final state of its working cycle - the polish has broken down, and it is ready for removal.
Don't work them until they start to dust because dust particles can mar the finish. In the end, you will end up with less residue, easier removal. There is no firm timeframe for the working time of a given polish. Count in factors like outside temp., surface temp., humidity, pad type, pressure, machine speed, etc. In ceratin conditions the product can flash. Flashing means that a polish reaches an unwanted dry state very suddenly, often without completing its working cycle.
