Buff and Shine Uro-Fiber Pads
VISITOR
Active member
has anyone had a chance to use these yet? how do they compare to some of the other microfiber pads out? looks like they are going to be available in 6", 5", 3", 2", and 1" sizes...
Buff and Shine
Very interesting, but i dont think that these would be the ultimate cutting pads since aio and extreme cutting wont work. I think there are enough one step pads what i want is microfiber pad that cuts, is good to drive and durable. Any thoughts?
One of my FB friends posted a video of this pad eviscerating 1500 grit on a 8mm random orbital, some compound, and this pad.
I wonder was it hard paint and how many sets he had to do? I hope these cut atleast as much as Megs mf discs.
Karl? and his HF unit
yeah he did use his compound and also used it with his essence type product, boh worked well
Ok sounds promising. I wish someone would eventually do a test with all these new microfiber pads. Buff and Shine, Lake Country, Americana Global etc.
How is the cutting power compared to megs and rupes? Rupes will also bring new versions of mf pads, no more color coded fibers
A local guy got one that we tested. Did pretty nice job removing 2000 grit with M100 on a legacy 21 (modded).
We didn't do any side by side comparisons though.
looks like B&S are releasing the uro-wool pads which will be available in the following 3", 5", 6" sizes...
also, the uro-tec microfiber finishing pad should be available soon as well...
Do these start peeling off the foam after the first or second use like the regular buff and shine junk mf pads?
Looks nice. I wonder when they introduce uro-fiber cutting pad instead of that original one step pad.
If your having problems with the starting to delaminate you are running them too hot. I've had mine for a while and probably have put 4 sessions on each and no problems. I just swap out every panel, check the temp while I'm polishing, use vented bp, and don't run full throttle, and no need for heavy amounts of pressure. You will blow up any MF pad running full speed. There is no need to run full throttle with any MF pad. I only go up to 4 and that's enough. I blew up a few MF pads in my time before I figured out you can't treat them like foam.
