ViperGuy21
- Apr 6, 2015
- 802
I was lucky enough to win these pads from the recent giveaway on AGO in return for an honest review.
Here is the product description taken from the AG store:
[TABLE="align: left"]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
Perfectly balanced for an unrivaled finish!
Uro-Tec Foam Pads are the latest innovation from Buff & Shine, a leading manufacturer of foam, wool, and microfiber buffing and polishing pads. Developed specifically for “long throw” orbital polishers such as the Rupes LHR 15 and 21, Griot’s Garage BOSS G15 and 21, and the new FLEX XFE, Uro-Tec Foam Pads deliver uncompromised performance on all paint systems and longevity that is superior to anything else on the market.
Buff & Shine Uro-Tec Foam Pads are available in two sizes – 6 inch and 7 inch, respectively. Use the 6 inch Uro-Tec Foam Pads on the Rupes LHR 15 and Griot’s Garage BOSS G15. Use the 7 inch Uro-Tec Foam Pads on the Rupes LHR 21, Griot’s Garage BOSS G21, and the FLEX XFE-7. No matter the tool, you will be blown away by the uncompromised performance of the Uro-Tec Foam Pads.
Buff & Shine has a reputation for manufacturing buffing and polishing pads that can withstand repeated use without failure, and their latest innovation continues this trend. Uro-Tec Foam Pads are constructed out of super durable open-cell foam which allows long cycle times without reduction in performance, and the ability to dissipate heat quickly. This results in a pad that lasts longer without any loss in cutting or finishing abilities.
Uro-Tec Foam Pads were designed and engineered from the ground up for use with long throw orbital polishers. From the unique foam construction to the thickness of each pad, Uro-Tec Foam Pads will blow you away with how smooth they are on your long throw polisher. And with Buff & Shine’s legendary durability, Uro-Tec Foam Pads will be one of the smartest investments you’ll make in car care.
Buff & Shine Uro-Tec Foam Pads are available in heavy cutting (blue), heavy polishing (maroon), polishing (yellow) and finishing (white). From our testing, we’ve found that Uro-Tec Foam Pads are compatible with the leading manufacturers of buffing and polishing compounds, including Menzerna, Meguiar’s, Wolfgang, 3D and more! Use with confidence and enjoy the new-found smoothness of your long throw orbital polisher!
My box arrived with all four of the foam pads, as well as a microfiber cutting pad and a microfiber finishing pad, which are not in the AG store at the moment. I also got some nice B&S stickers and a product catalogue.
Initial impressions:
-These pads seem very well made and very tough. The foam seems of very sold construction and the velcro backing seems to be very well adhered to the pad itself.
-The foam pads are pretty thick(1.25")but I had no problems with stalling or slow rotation
-I like the wider face and smaller backing, helps squeeze into edges around intakes, spoilers, etc...
Conditions of use:
-I ran these on my GG6 with no issues whatsoever. I was a little worried about stalling, but had no issues.
-Test subject was a white 2010 Porsche 997 911 GT3. Damage wasn't that bad but was significantly swirled.
Thoughts:
These pads rock! The blue, maroon, and MF cutting pad all cut really well and fast. I also noticed that the Maroon pad finished really well, even with a compound(Sonax CutMax). The yellow, white and MF finishing pad did a really nice job of removing the(very)slight haze left after compounding and adding some nice gloss with my polish of choice for the job(Chemical Guys V38). Compared to the Hexlogic pads that I have been using(also manufactured by B&S)these cut and finished better, and also didn't clog up nearly as quickly. This was probably my favorite part of these pads. The Uro-Tecs just simply kept going and going without a change in cutting or finishing ability. What I used one Uro-Tec maroon cutting pad for, I had to use 2 hex pads and had to switch between the two hex pads after each panel because they got so dang hot! The face of the Uro-Tec never seemed to get very hot, probably due to the cooling hole in the middle of the pad. Overall these pads were a true joy to work with and have become my new favorite pads and plan to get a full set of these at some point. The only thing I did not like was that the maroon pad, as well as both MF pads both shed for a panel or two, but it wasn't too big of a deal. I will try and update this review with longer term pad durability.
Thanks to B&S for the opportunity to try these pads out!
[TR]
[TD][/TD]
[/TR]
[/TABLE]
Conditions of use:
Thoughts:
