Mfoehrkolb
- Oct 1, 2012
- 16
I just picked up a completely new set up for after i respray customers panels and or overalls. I have 2 pads of each as of now, i didn't want to buy more because never using this set up before.
I will be using a 5.5" rotary for the compounding stages, and MAYBE the first pad of machine glaze. Then i will be moving to my 5.5" DA to finish off the machine glaze/machine polish/hand glaze steps.
I picked up the 5.5" buff and shine pads, and mothers professional line. The diagram's below are what i planned on following, just not sure what one to choose #1,#2, or #3. Or if anyone else would suggest a different combination of product/pad order for myself. If not a different combination, which from the bottom would you follow.
(Aggressive to Least)
Heavy duty compound>Rubbing compound>Machine glaze>Foam pad polish>Hand glaze (only one that contains fillers and is put on with no cut pad)
This is a link to the pads: (autogeek doesn't carry them
flat foam pads, flat foam buffing pads, car polishing foam flat pads, DA foam 5.5" pads, flex foam pads, pc foam pads, megs g110 flat foam pads, 5.5" detailing foam pads
This is a link to the mothers professional line:
Mothers Professional Refinishing System, Mothers polishes, Mothers compounds, professional polishes, reconditioning system
