Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Nice,
Holograms is a specific word or term to describe a very specific scratch pattern inflicted only by a rotary buffer.
ANY brand and type of orbital can induce micro-marring, but not holograms. And as long as you're using great abrasive technology you won't induce micro-marring. You do have to be careful wit pad choice as even a pad on an orbital can be aggressive enough to induce micro-marring.
This is why we all do a
Test Spot
To dial in the right pads, product, tool and technique to prove we can make one area look GREAT before buffing out the entire car.
You can burn through clearcoat by HAND if the paint is already thin. This is why it's a "Best Practice" to no buff on edges or raised body lines.
This is one thing that I like about my classes - you get to use all the tools before plunking down your hard-earned cash.
The new G9 is very good at maintaining pad rotation.
The BEAST, CBEAST and Supa BEAST are all gear-driven - you'll never have pad stalling with any of these tools.
Tough choice. Both are great tools. I tend to look for maximum speed for getting a job done and when you spend enough time behind the BEAST you can make it dance on paint.
Cost is not an issue, so if I spend $200 or $500 on a polisher, I am OK with that.
A couple of concerns I have with the Flex, is can I introduce Holograms in the paint (2 of my cars are painted black)
Test Spot
and can I burn thru the clear coat on raised edges?
