215Detailing
- May 19, 2011
- 1,063
I want to do a small portable unit to move around a lot, see DMW CART AT: TractorByNet.com - Compact Tractor Forum (Re: pressure washer to draw from a tank??
I use a Comet AXD 2520 pump with a 4hp Honda GC engine with no problems ( 2.5 gpm @2000psi). No problems with it drawing the water from the tank. It originally came on a 2 wheel hand cart, but is wasn't practical for my useage. Put it on a small wagon with a 30 gallon tank to make it portable.)
I pretty much want same type of set up 35 gallon tank, but considering use a PREDATOR ENGINE; ( http://www.harborfreight.com/engine...hv-horizontal-shaft-gas-engine-epa-60363.html )
now what would be the right pump (CAT,AR,KARCHER or GENERAL) to use with this engine to pull water through, looking to do 3 vehicles and photos or video will be a big help also looking to have a bypass on pump to recirculate water as to not cause damage to setup
