215Detailing
- May 19, 2011
- 1,063
With gas you need a pump. Some electric models have self priming pumps and don't require an external pump. However, most of those models are karchers and if you are spending only a few hundred on it, you are getting a consumer model that won't last very long. I just got the Kranzle K7. Expensive but its self priming, 10 year warranty on the manifold, service center is local, and it doesn't require a return line because its engineered in such a way that it won't overheat. You can leave it running for an hour and do zero damage to the unit. Id suggest getting one
(NEW POST) = MOBILE SET UPS (pressure washer & water tank)
I'm considering buying a small KRANZLE electric pressure washer (K-1622 model).
cannot seem to find any videos of units (electric) hook up to a water tank pulling water.
if any forum members can upload video(s) how they connect units (pressure washer) gas and/or electric to water tank solely and post a video I believe it would be a big help to other members
