frankprozzoly
- Mar 28, 2014
- 1,596
What to use and how would you clean the calipers before painting
The question I've always had is: can you powder coat a caliper without removing the piston from it's bore - or without removing the outer rubber dust boot from the piston? Since removing the piston means basically rebuilding the caliper, that would be a lot more work and require a compressor. But, if you can just unbolt and tape up your calipers (piston/boot), pinch off your brake lines, and bring the calipers to the powder coater - that is not too bad.
I'm not intimately familiar with the powder coating prep process, so I don't know if the prep involves submerging the caliper in something that could ruin the rubber boot? Or, can you just seal up the brake line connection point and tape up the boot/piston?
