RaskyR1
- Apr 14, 2008
- 3,733
I've not yet used the Power Finish so I can't say how it works. It's designed to be a 1-step polish so on most paints with a finishing or polishing pad, you should not need to follow it up. Using the same pad on the DA and rotary with Power Finish, will remove more defects, and faster, with a rotary. All paints react differently, which is why you should always do a test spot.
To answer your question, the rotary will be faster, and more effective, and has the ability to produce better gloss on some paints than a DA.
Rasky :cheers:
Rasky :cheers:
