Can clay barring cause scratches on a new car?
I would. But be CAREFUL when claying, don't want to have it looking all marred up underneath. ;)
So to be safe on my car, I should make sure I apply plenty of clay lubricant and constant kneading of the clay bar? Do you recommend a good clay for a car that has extremely little paint contaminants, I am using the OTS mothers clay but I feel as though there is something much much better
These stories scare me right out of trying to detail my car ;o( I purchased over $900 of products, including 2 orbital buffers from Auto Geek and haven't opened the box yet. My car is torch red and has swirl marks and I would love to have a nice mirror finish. I'm just afraid of making a rookie mistake like this.... I hope to take the plunge soon (before my wife finds the box in the basement ;o) ) Good luck rkelmy!!!!
Don't worry. No one mentioned before (I've tried to read the entire thread), in my opinion, the main error OP did was using an aggressive pad (orange) on (what others related) very soft paint.
Like said by many, after claying it's good to polish. However, to remove clay marring (always present at some level), just the first pass is enough.
That said, you don't need to worry about claying your car, if you're going to polish afterwards. Just the act of polishing will remove every marring clay may leave, because it's pretty much always superficial marring, only.
However, if you are going with an orange (aggressive) pad without any criteria or proper technique, over a soft paint, you'll leave noticeable scratches on the paint.
Solution: Always do a test spot before polishing. Dial-in a system that will be able to remove the defects you're observing. Start trying the least abrasive method first. Inspect the paint in many light conditions, including your swirl finder light, after every section.
Clay new cars is a common practice here, I'm yet to find a car that don't need any claying at all.
The solution to OP would be to re-polish the car using proper approach.
If the light polishing or finishing pad aren't removing the defects to desired level, you may use an aggressive pad at first, but more steps later for further refinement, using a polishing or finishing pad (the test spot will tell you).
After perfecting one spot, you just reproduce it to the rest of the car.
The error in this thread relies on lack of observance, lack of criteria, lack of test spot, and use of aggressive approach on a soft paint.
IMO.
Don't be scared, educate yourself, ask before trying if you're not sure enough. We are here to help.
Kind Regards.
