I throw mine in the washer and let them air dry felt up.
I use the towel drying method Mike has on here, works very well. I also bought a simple dish drying rack. It lifts them and allows air to access the foam when laying face down. I can fit six 6.5 pads easily at one tme.
use a thick mf towel or terry towel and fold the pad in it. Press the towel against the pad and all of the water transfers from the pad to the towel. Works really quick. Mike has a post somewhere on here, cant remember exactly what its called....
Oooooh, did that blow your mind or what!!!!
I actually throw them in the washer after I soak and thumb wash them in a bucket with DP pad rejuv. I then put them in the wash with some microfibers(used to remove polish) using microrestore.How do they turn out? What detergent do you use?
How many washer till the pads will break apart? The backing is velco, I thought it can damage the pads.
Obviously a front loader will be gentler than a top loader,How many washer till the pads will break apart? The backing is velco, I thought it can damage the pads.
I was actually just looking for this answer. Glad I can put them in the wash. It will make things much easier.
