Charleston
- Apr 18, 2012
- 340
Can I apply/polish in D301, wipe off, and then immediately top with a sealant like blackfire wet diamond?
Sure you can.
I will emphatically say yes!Can I apply/polish in D301, wipe off, and then immediately top with a sealant like blackfire wet diamond?
Why would this combination work so well,
i.e.: Applying a Sealant over Polish/Glaze...
{BFWD over BFGEP}
BLACKFIRE Wet Diamond All Finish Paint Protection
Directions:
"For best results clay the paint first with BLACKFIRE Poly Clay and polish with BLACKFIRE Gloss Enhancing Polish......."
BLACKFIRE Gloss Enhancing Polish:
The polish and glaze in one that creates WHIPLASH!"
"BLACKFIRE Gloss Enhancing Polish is a remarkable finishing polish with a built-in glaze for the ultimate "wet-look." Used before your LSP (last step product), BLACKFIRE Gloss Enhancing Polish improves the gloss and clarity of the finish."
"Gloss Enhancing Polish is designed for enthusiasts desiring the deepest, wettest gloss. When used under BLACKFIRE Wet Diamond All Finish Paint Protection, it's pure magic!"
_________________________________________________
And then think that the below combination won't work, or won't work as well?
{I.E.: topping a Hybrid Sealant (D301)...with a Sealant (BFWD).}
Meguiars D301 Finishing Wax
This blend of mild cleaners, polymers, silicones, and carnauba...
So to answer your OP's question:
First:Ok guys, help me out here...we usually talk about not putting a sealant over a wax...D301 contains wax, so in my mind I wouldn't put a sealant on top of this. I feel like I'm disconnected here somewhere given all the trusted names I am seeing in the replies. I am always open to continuing education, so what am I missing?
BFWD over BFGEP makes sense in my head because it's the same family and should be formulated to work together. I get putting a sealant on top of AIO's like BF TPnS topped with BFWD or Uber AIO topped with WGDGPS because the polymers will work together being in the same family.
Since D301 already has polymers and wax for protection, by adding BFWD, are you maybe not maximizing the benefit that each would provide on its own?
Thanks guys!
•Unless there is quite a bit of wax that's mixed-in D301's "Conditioners", or "non-hazardous Mixture"...I see Meguiar's D301 as being more of a Sealant-based hybrid product, than a Csrnauba Wax-based hybrid.Ok guys, help me out here...we usually talk about not putting a sealant over a wax...D301 contains wax...
^^^Sure thing.^^^Thanks Bob. Sounds like the jury could still be out, but I guess it sounds like people have done it with no ill effects. If it works, it works.
Carry on...nothing left to see here. :dblthumb2:
