View attachment 50634View attachment 50635View attachment 50636 I ended up taking 600 grit wet sand all the way to 2000 grit them buff that out with 3M rubbing compound with Makita rotary buffer
View attachment 50557View attachment 50558
My boat has been sitting for 5 years in the open weather and has built up the oxidation/faded look as seen in the photo. Tomorrow I'm going to paint correction to the hull.
What grit sand paper for wet sanding should I use I was thinking 1200 grit?
I'm going to use my Mikita rotary with a wool pad and Meg's marine compound to remove the wet sand scratches.
Follow up with polishing with my mt300 6" black thin foam pad
And wax with PC using a black hex waxing pad.
Will this work I haven't choosing my polish or wax to use yet I was thinking HD speed but idk if I should test that on a boat or not.
Is that a finished photo of the rear quarter?
