Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
- Thread starter
- #21
Thanks for the info. I have both the cordless flex from AG (rotary n orbital) n will try them out this weekend
Don't try to machine sand with a rotary buffer. When you sand with a rotary buffer it's no longer called sanding it's called grinding.
Use the orbital to sand and then use the rotary to remove your sanding marks.
What do you have for a wool pad for your cordless rotary?
