Rsurfer
- Jan 26, 2007
- 14,163
- 26
:iagree:about removing a lot of defects by wetsanding and then polishing. I've corrected scratches and rock chips by wetsanding and never had to wetsand the whole panel. I did shoot 3 coats of clear over the repaired area if that matters.Just wetsand the area and take a wool pad and cut and then polish.... should be able to remove 75-80% of all the defects... Remember when wetsanding, do not just wetsand the scratches or you will create a "valley" in the clearcoat. It is kind of like blending in paint per say.... so you will need to wet sand the whole area.
