Can you use pinnacle ultra clay more than once
Alex Haramic
Can you use the pinnacle ultra clay more than once if the clay is still usable and doesn't have a lot of junk on it?
Absolutely, just remember to kneed and fold into itself to give you a fesh surface every so often. A clay alternative such as the speedy prep towel or nanoskin sponge is better bang for your buck as these types can be easily rinsed off and used over and over. Another plus is if you drop it, just hose it off and go back to work as with clay if you drop it, it is trash.
Absolutely. Unless you drop it or you pick up some other abrasive stuff, you can fold it a few times and go. If the vehicles aren't too bad, you should get 2-3 in before it gets gross enough to toss. If you see it starting to mar the surface, toss it. Better safe than sorry.
