greatwhitenorth
- Jun 23, 2013
- 356
I'm trying to embrace change from my trusty foam flat pads so I bought Lake Country 5.25 Microfiber DA Ultra Fiber Pads.
I have been using them on the panel the same as the orange foam pad, same passes, arm speed, etc but the cut is nowhere close to the orange pad with the same compound. I have cleaned the pad with air after every section.
Heres a shot after one pass with compound, the right half is MF (still not acceptable) and the left is B&S orange flat pad.
Any tips on getting better cut?
Another question I have is how many MF pads do you use per car? I found with spraying the pad with air after every section it didnt get dirty at all.... is doing a car with one pad odd?Feed back please
THANK YOU in advance
