I use covers every day.
The trick with applying/removing is to fold the left hand side, and the right hand side, to the center.
Then, start at the front and roll it towards the rear.
To reinstall, lay on the trunk and unroll, then fold each side down.
Done in this manner, the "outside" of the cover never touches the paint surface.
I don't think a cover will "soak" up the wax.
BTW, I prefer "Dustop" material for indoor use, and Evolution 4 for outdoor use. It may be bulky (because it's 4 layers think), but it protects against door dings at the airport. I prefer custom fits because the mirror pockets help to hold the cover in place. If you have a fixed antenna, unscrew/remove it instead of punching a hole in the cover. I use a cable and lock when I leave mine on at the airport, so no one steals the cover.
I bought a "Noah" car cover for the outside to use on our Cobra till we got a 63 Pontiac out of our garage. I forget the mfg but it was a custom and a very good one. I use a soft blanket in the garage because we found the all weather cover scratched our black paint no matter how gently we put it on or took it off. We used the roll up method described above. So we switched to the blanket for the garage. In the future I'd like to get a lightweight nylon cover for the garage. I hope your cover doesn't scratch your paint.
