Car pro essence
Msdetailing
Well I've been reading good things on here with regards to car pro essence.
Over here in the UK it hasn't been around as long as it has on the states.
I was thinking this could be a product I use for "dealer" production work.
My normal production is a 1 step with megs D300 (which I love) just wondering if essence could A) take place of D300 on dealer work or B) ad anything to dealer work I get in?
I was thinking of D300 then a couple of quick passes with essence.
I personally think it would take to much time for a 2 step dealer car,I would go with a good aio or d151 and spraywax it.I think of this is he paying above average and feeding you all the time at 150 to 175 per car.if so then do him right on a 2 step,getting back to essence it may or may not work in your favor I find it a little bit more time to work with to max out the benefits of essence look.There are a lot of polishes out on the market that are cheaper and gives you gloss at the end of the day.me personally wouldn't use essence on a dealer car to expensive I think but a great product.
Thanks :D
Over here in the UK I charge a dealer £75 so around $125 USD. these only take half a day and I guess since I've fallen in love with d300 I will carry on using that :)
Over here in the Uk there really isn't much call for a AIO.
Essence would not be able to take place of the method you are using now.essence is a aio filler type product with extreme gloss.The 300 you are using is more of a corrective cleaning polish that remove moderate swirls and light scratches and when used with a rotary that 300 really cleans defects fast.
I use d300 on my Rupes 15 and Mini and havnt found anything better.
For 125 just stick what you have.300 is a good product though maybe a little rough on paint to use on every single car.Thats all you can get over there?
No I've got stacks of other products. But fallen in love with d300.
Haven't Tryed finishing it with m205 on a white foam next, that's my plan.
Try using 205 with a cutting disk works great and in most cases no hazing or marring,one step and your done.
You should order a gallon of 3d HD speed. You will certainly love it.
