Car Stereo Problems
abrcrombe
Hey guys,
I have a problem with my car stereo and was curious if anyone knew what was going on. I have an aftermarket deck and speakers. Works fine, except sometimes in the morning (when it has been cold at night), the passenger side speakers don't work. Front and back. Usually after a few minutes, they kick in... often times when something jars that side of the car (open window, slam door, pothole). This doesn't happen in the summer, and it is kind of annoying to hear only half the song. If anyone could help, thanks.
BTW - both were installed by "pros", meaning it wasn't a self install.
If they come back on when slamming the door or otherwise just pop on durring driving, you have a lose wire somewhere. If you know how to remove the panels follow the wiring from/to the door and pull the deck out and check the connections. The wire can be barely just lose and soemthing like vibration from driving or closing the door is enough to make it "connect" again. Check the terminals on the speaker as well if you can.
:iagree:
Agreed with surfer sound like just a loose wire some where.
Ok thanks guys. I am going to pull everything apart on my next day off.
Ok, so I took off the door panel and checked the wiring to the speaker. It all seemed fine. It must be at the head unit then right? How do I take it out? It is a pioneer, and do I need a special tool? Does someone have that tool that I can borrow? (I'll pay you to send it to me)
I use to have these funky looking wrench things, forgot what they were called when I did my other systems to remove decks. They have two flat prongs that protrude that release the clips holding the deck in. Call up any car audio type place near you and see if they have them or if you can borrow them. Some are different though, some are flat and some are round prongs, I use to only use Clarion so they were flat, I think Pioneer is the same.
If I knew where mine were I'd send them to you.
edit - heres what the round one looks like
thanks Surfer, I'll go try to see if I can buy some today.
1st look at your deck and see what type it takes, look on each side and you'll see two slots per side, they'll either be round like above or slotted like:
l l
l l
It's slotted, see where those two metal bends are that hold the dash plate on the side, the tool will slide into those and unhinge the clips and then you just pull the deck out by pulling on the tools at the same time.
Call an audio shop near you and they might just let you come by and borrow it quickly to pull the deck out, heck they might actually help you and not charge you, I've seen places down here that are friendly like that. Otherwise you can pick it up for a couple dollars, though it should have come with your deck? I know my Clarion decks came with it and my sisters Pioneer I'm pretty sure came with it as well, but I have no idea where those tools are, somewhere in the garage lol.
I can't find the box... so you just stick it in there and pull? What keeps it from just sliding right out (the tool)?
teeks said:
i used to have a pioneer deck in my old crx, the tool you need is like this
*edited link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230078419093&ru=http%3A%2F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Fcgiurl%3Dhttp%253A%252F%252Fcgi.ebay.com%252Fws%252F%26fkr%3D1%26from%3DR8%26satitle%3D230078419093%2509%26category0%3D%26submitSearch%3DSearch%26fvi%3D1
it fits into that small channel between those two metal tabs, i think if you just take a long flat piece of metal it would work just as well, but im not quite sure because i dont remember what the end of the tool looks like
Yup, I got confused for a sec, on my Clarions I used to have I actually needed a two prong tool (just like above but had two at the end), but my sisters Pioneer had single input. Haven't installed a system in years, forgot what they really looked like.
Abercrombie - the tools have slight raises on the ends at an angle so when you slide them in it unhinges the clips which it turn catch the tool so you can pull it out.
the tool inserts here (see circle on pict)
and has a small hook on the end (much smaller than what i drew) that clips in to the side of the unit, it pushes aside a tab that lets it slide freely and at the same time catches in the side so you can just pull back on the tool to slide the whole stereo out, i think if you just use a flat piece you should be able to pull it out by hand even though it doesnt have the little piece that catches the side
