Carpet Dryer Advise
My Detailing Guys
After carpet/ seat extraction do you use a carpet dryer fan to speed up the drying process? I checked out the AG carpet dryer which puts out 500 CFM, any one using this fan?
Any recommendations/ advise would be appreciated.
Greg
I was going to ask this question yesterday but got side tracked doing other things around the house. I am curious myself!!!
Do you feel the Shop Vac puts out enough air to dry carpets or seats in a timely manner, or is it an all day process?
Thanks,
Greg
Thanks,
Greg
If you extract or towel dry first, only takes a couple of hours max. If it is very warm may take less.
Don't waste your money. Crack the windows about a quarter of an inch, start the car and turn the heat on full blast. The car will be dry in around 20 minutes if you haven't completely soaked it. I've done hundreds of cars like this. Also, you will be able to catch any stains that try to wick back up, as the car dries, and you will be able to spot them with folex or a similar product. Blowers and fans are a waste and won't work nearly as fast as turning on the heat.
On older vehicles I watch the temperature guage every few minutes, because some older vehicles like to overheat when idling.
Good luck
Good luck
Ditto
