The Kid_Detailer
- Jun 28, 2007
- 11
What do you guys think is the best stain remover for carpets? is meguiars quik out carpet stain remover any good?
j_anderson_23 said:is 10-1 mean 10 parts water to one part woolite, and is it the fabric softner cleaner your talking about for clothes
DantheMan said:This was done with folex and my first time using the bissell little green machine..
I'm sure the commercial stuff is alot better than the LGM, but for the weekend warrior I think its a great thing.. I was honestly going to throw those floor mats away and try to find an OEM set ('93 Cobra, well over $100/pair if you can even find them). Probably could've done even better if I had a brush for my PC..
P1et said:I use Water/Woolite as it works perfect. Also use it on my leather. But for stubborn stains, I grab the Folex.
r_wain said:I use Meg's APC PLUS (10/1 same dilution I use for everything) and a small brush. I was going to try Woolite but the APC works really well and it is one less bottle for me to carry. I should point out I have a extractor so I can get the soap out.
With the Woolite mix do you extract it or leave it in?
D&D Auto Detailing said:Can you explain your process for using this on carpet?
Do you use the 10:1 APC on leather too?
r_wain said:Yeah to clean it then use a conditioner on it. I use it on carpets, seats, vinyl, leather, pretty much everything.
D&D Auto Detailing said:Did you see my thread and surfers? Megs APC diluted 10:1 has a pH of over 12. That can remove the dye from leather, and removes the natural oils.
D&D Auto Detailing said:True, but Al also brought up a good point that it has to also have something to do with the actual product being used. Better safe then sorry either way.
And same thing goes for cleaning leather as polishing paint. Start with the least aggressive combo. So you could even start with warm water and MF.
