Carpro Darkside; blotchy, streaky??
The tires are Nokian, brand new but probably are 2 months old since they came out of the factory. When I cleaned them with the drill brush, there was no brown, it was just white suds from the Brake Buster. Then Tarminator wipe.
They are still off the car, inside, so I applied the dressing inside. They are to be installed on the car in 2 days.
I'm gonna try again on the 2 tires I haven't dressed yet. I'll apply a coat of Darkside and wipe/level right away.
Maybe it's because I'm looking at the tires up close, on the car they may not look streaky.
Not sure if a second coat will help, or maybe a top coat of a different gel; I have some old Wolfgang, it's a liquid now but I still used it before winter when the car was new; however, those were the OEM tires, Bridgestones.
Clean them at least 2-3 times with the drill brush and BB. If you have an APC try that once. Better too much cleaning than not enough.
Too late to clean any more. After 2 coats of Darkside now, worked in and wiped, the tires don't look too bad.
Having them installed today, I'll post a pic later.
