Carpro EcH2O and Reload ratio...what do you use
MrOneEyedBoh
Active member
So what seems to be the most common mixture of EcH2O and Reload? Curious to see what you all use. Is be using this as a drying aid/ topper for McKees 37 paint coating. Looking to mix up a gallon of this stuff.
I am mixing the ratio on the lean side and having great results.
For Ech2o 1 oz to 20oz water. Reload at 2 oz to 20 water. So for a gallon approx.
6.5 oz ech2o and about 12 oz of reload.
10oz Echo2o, 10oz Reload and 100oz water.
1.5oz of ECH20, 2oz of Reload and 28.5oz of distilled water for a "topper." This works very well and is conservative of product.
2oz of ECH20, 2oz of Reload and 28oz of distilled water
Hoping Eldorado would pop in. I think he has his own mixture too
This is the exact mix that I did for my 1st bottle.^
However, I think I'll be moving away from mixing Reload into it as I see no additional benefits [i.e. It doesn't hide light swirls the way Reload undiluted does. Reload smells horrible. I can't imagine all the shine coming from Reload alone]
Overall I've been pretty let down by the lack of smoothness when using the Ech2o/Reload mix. The towel just drags... I'm looking forward to using Ech2o on it own @15:1
Sent from my iPhone
Are you still planning on using reload as a topper here and there?
I'm not a big fan of Reload because of its weak protection. However it really excels on black vehicles due to its nice shine and ability to hide swirls when used straight.
Sent from my iPhone
Damn. I just bought it for nothing pretty much then lol. Maybe I'll throw an oz in. I'm sure some would help more than not using it
After going through an entire 32oz bottle of Ech2o/Reload mix, I retract any negative comments I initially stated about it... It just took a bit of getting used to the feel of applying it, I had to remind myself to sort of treat it more like Reload than what I was expecting [I guess I got used to Wolfgang Uber]
But more importantly, the final gloss left behind from using Ech2o mixed with Reload is pretty phenomenal... But I want to try see what Ech2o can do on it's own, so I mixed up my 2nd bottle with only Ech2o @10:1 I'm about to try it out on my car.
keep us in the loop, I have ech20 mixed with cure ATM, but I was suing straight ech20 prior to, it still had amazing gloss and shine, not to sure on durability as it was never to long between washes before I applied something else to my car to test that out..lol
Sent from my iPhone
It seems a bit fussy on black paint. Even the newer version.
I tried Ech2o in a few ratios, and found it streaky at a greater concentration than a 1:20 ratio. All sorts of reasons why that may not be the case for others, but at 1:20 on it's own on a coated car I really like it.
This stuff looks good after you apply it but I swear it makes the car more dirty over the week. The water spotting even with these light roast products is terrible and every little water spot traps it on little pocket of dirt/grime. If you don't get to it in a week every week it's just going to be a mess.
What is your LSP that you apply Ech2o mix on? It's quite a low grade protection that would get you between washes hardly. Maybe a week or two max. So think it's more about the protection you apply it to that is water spotting sensitive. Just a thought thou.
2 oz ECH2O, 3 oz Reload substitute, 27 oz distilled water for my drying aid and QD. Use 2 towels, 1 one to spread and 1 for final wipe. You don’t need to use much. Over applying will cause streaks (same for any product).
Good to hear my friend. I've been mixing up and providing my customers the "blue juice" since it came out and I first played around with it to find my perfect combination.
I still use the following and love it.
32oz Empty bottle
1:20 Ratio ECH20 and Distilled Water
3oz CarPro Reload
I find even on black ZERO issues with streaking or haze. Very basic Spritz onto a damp MF Cloth and wipe away. By damp, I mean I never dry or wipe the vehicle with a dry towel when washing and finishing up my drying. I always keep a gallon of Distilled water and Rinseless mixed up and I soak the rag and wring it out until it's just dampened. Use the blue juice and you're good to go from there.
