The Guz
- Jun 17, 2013
- 8,793
- 69
Is hand application another recommended option, or is machine the main way to go (per directions)?
Can be used with either method
Via Dual Action Polisher:
1. Prime CarPro Gloss pad with Essence PLUS
2. Apply with no pressure in multiple overlapping passes on speed 1-3 across 24” x 24” (60cm x 60cm) section
3. Clean pad with brush and apply 3 Pea size drops to the pad
4. Move to next section and repeat steps 2-3
5. Continue around ENTIRE vehicle in this manner and allow to cure for an hour
6. Wipe excess residue off of entire vehicle
Via Hand:
1. Wash and dry Vehicle
2. Apply a few pea size dots of Essence PLUS to the applicator
3. Apply in overlapping figure circular motions across 24” sq. +/- and work into surface similar to a “polymer sealant” (liquid wax) application method
6. Allow to cure for AT LEAST an hour
7. Easily wipe excess residue off of entire vehicle.
How important is it to let essence cure for an HR or more before you top with plus?? I just realized I don't normally let it care for that long... Maybe 30 mins or so on average.
Sent from my Pixel 2 XL using Tapatalk
That is a question for Corey or Avi but I would imagine 30 min would be ok. Is the amount of time it takes you to get around the car? Or are you basing the time after you have completely finished?
Here is something from CarPro's site
Q. How long does it last?
A. The truth is we cannot yet say. We have not yet tested to full capacity and we will certainly keep you updated as continued testing from all climates comes back. Early testing suggests months of beading and up to a year of repair to faint swirls.
I will add that when I used Essence Plus over a coating that was over a year old, it did not last long. About 3 months the hydrophobics were almost gone. I tried the essence twins on a harley once but that is not washed as often but it did look great.
