I’ve been tried and true with menzerna but will to shop around for new products. Looking to get a heavier cut compound was looking at ultimate cut from sonax or carpro ultra cut which one would u guys go for?
Just wanted to get something abit more aggressive then fg400 wondered if cutmax was the step up or will it be ultimate cut? I will never have severely damaged paint either lol. I never tried carpro compounds either always stayed tried and true with the Germans
Forgot to mention I will also be using it alongside a denim pad and possibly a microfibre cutting pad too!
Denim is supposedly pretty coarse so I’d recommend being careful. I don’t have any experience with denim but for paint that you say is in good condition, I wouldn’t necessarily recommend such a coarse pad with such a coarse compound. Microfiber cutting pads are decent but after switching to the Rupes wool pads, I can’t see myself going back to microfiber pads as the wool finishes so much better. And I have quite a few Meguiars cutting and fine microfiber pads.
Remember, paint is thin and clear coat is thinner. Only go as aggressive as you need to address the defects and no further.
I have some orange peel I need to address further I have done some 2k wetland lightly and then fg 400 over it I got rid of id say 50% of it but all I wanna do is try to match the factory orange peel which is another 15% to go. I opted for denim pad since I can use it on a da and adjust which type of compound I would need for this and I read that ultracut is the preferred one? not throwing shade on Sonax cuz I can opt to purchase that one as well!
Ok. Now it makes more sense that this is a respray. Repaints are normally thicker but you still need to be careful with the thickness. Ideally you’d have a thickness gauge to validate thickness so you don’t go too far. The last thing I’ll say is be careful and go slow, meaning you will be better off with a little more orange peel than going through the clear coat. Good luck
correct I don't want perfection as im trying to save as much clear as possible. which compound between Sonax cut max and carpro ultra cut would u take in your arsenal to tackle this job without putting to much stress on the pad itself. will a microfibre cutting disc with a heavy compound remove orange peel as well?
