ceramic clear coat
faisal
Hi Guys
need some help
Questions is
1- what is the Advantage of Ceramic clear ?
2 - if we spray 2 full coat how many micron we will built and how many micon will Nano particle in clear ?
3- what is the Harden of cerqmic clear example opti- coat 9H ? so what about Ceramic and normal clear H ?
4 - if car been sprayed with Ceramic clear how can we know if this car been sprayed in body shop with Ceramic clear ?
5 - when we spray clear coat is there any solvent evaporations happen ? and how much ?
6 - after spray the ceramic clear when it get harden 100% ?
7 - is same manufacture ceramic clear harden we get if we spray here ceramic clear ? or manufacture ceramic will be more harden ?
8 - UV clear advantage and is it has same problem in polishing time ?
9- Which is more harden Ceramic clear or UV clear ?
Sent from my GT-I9100 using AG Online
I think your not getting the replies your looking for is because your post is a little overwhelming.
I don't like to see a post with no response attempts so I thought I would at least post to give you a BUT (Bump Up Top) :)
I will give it a shot,
1. Harder, spray thinner, last a lot longer, more cost effective
2. That is hard to say, comes down to your guy spraying
3. Dont have an answer, but I have read cerami-clear is 50% harder than a dupont suprashield
4. ??????
5. I really do not know, phone PPG
6. Depends on a number of variables, when in doubt, phone PPG
7. If you use an OEM specification, it should be the same. Ceramiclear is Ceramiclear, it really doesnt vary too much. When in doubt, do what the can says on the side with regards to mixing
8. By UV are you talking about UV cure CC??
9. Ceramic is harder than acrylic (depending on the acrylic too, 2K is most common and then theres 1K too).
The questions you have are really for an experienced body works guy. This is pretty much the extent of my knowledge.
Thanks for your reply
any one can get me contact Or E.mail for any Lab or DR ....
Thanks Again
Thanks Again
You could try a post over at autopia.org asking Ron Ketcham your questions. He worked in the automotive paint industry for many years.
Thanks
I contact MR Ron Kecham he is the one who answered my questions
Thanks again
