First off, congrats on the new car. What did you get? Sorry if it's already been posted earlier.
Secondly, welcome to AGO!
Before diving in, you may want to watch a few videos:
http://www.autogeekonline.net/forum...wash-gentle-approach-aggressive-approach.html
http://www.autogeekonline.net/forum...o-ever-how-machine-buff-car-start-finish.html
Me personally would follow what others have suggested:
1.) Wash & Chemical decon (clean wheels, tires and wells first....)
2.) Inspect the paint (use the baggie trick), then observe under light LED flash light or Flex Light
3.) Mechanical Decon (clay or Clay Mitt) - use plenty of lube
4.) Preparation: Mask any trim, cover windshield with large beach towel, cover wheels (since they're already clean). Mask off any badges or decals you don't want want the polisher to grab.
5.) Mask off for several test spots, use the least aggressive method in your first test spot.
Why do a test spot? If you complete the entire car and are not happy with the results, you have to do the entire car again. Test spots allow you to dial in correction to a level where you feel is acceptable before continuing on with the rest of the car.
Why two test spots? Different products and pads will yield different results.
6.) After compound / polish follow the instructions of the last step product. You may have to do some kind of wipe-down (i.e. Car Pro Erasure) or use a non-abrasive polish to remove the polishing oils. Final wipe-down
7.) LSP - Coating.
8.) Finishing touches.. chrome, glass, cracks crevasses... and don't forget to clean inside the fuel door!
For areas that are hard to reach, you can try doing it by hand with a foam applicator, but I have to admit, the results will vary. Nothing removes defects like good product on quality pads with a machine. For tight areas, save up and get yourself a Rupes iBird Nano or Flex PE 8. Perhaps skip the tight areas for now and save that for next years "touch-up" when you get the proper tool.
For the areas where the dealer left you gobs of wax build up, you can try various things, but I would recommend:
McKee's 37 Wax Remover for Plastic removes dried on wax from plastic rubber vinyl trim
Or, some good No Rinse Wash Solution in a higher concentrate.
Good luck with the new vehicle! Remember to drive it, enjoy it, get it dirty! Detailing it is the fun part
