I finally got around to applying my first ceramic coat - CarPro lite.
First off we need photos lol.
I did my wheels and all painted surfaces but didn’t do the lights. Can you coat the lights?
Yes. You can pretty much coat any surface.
The experience went well but lighting was an issue in a cramped workspace. Once I pulled the car out in the sun I couldn’t see any high spots. About 4 hrs later it was cloudy so I had another look. I found maybe 3-4 tiny high spots under the doors and just applied a little more product and they came off easy. All in all I’d say lite is pretty easy to use. Does gloss enhance once it cures?
High spots are to be expect. Not the end of the world. CQ Lite has a forgiving window to remove them.
Gloss will pick up. A majority of it comes from polishing. If it is a lighter color then sorry to be the bearer of bad news, but they just don't have that wow factor like black.
it took me around 2hrs per coat though, just wheels and paint. I feel like this is a long time. How long should one coat take?
It takes as long as it takes. No need to rush it if you are not doing this for a living. Plus it is the first time so to be expected.
I might coat my lights in a few weeks once every has cured. If I don’t get around to it, I will definitely make sure to cover them with Elixir during maintenance washes so they have something.
If you are going to coat the lights after the first wash then don't use Elixir on the lights. No sense in working backwards. I would actually consider adding PPF to the lights.
In 25hrs I did a decon snow and wash, cleaned all trims and badges etc with a brush - btw I just couldn’t kill the existing product on there which was Megs hybrid ceramic wax. Tar remover to all wheel arches etc, thoroughly cleaned wheels. Then used iron x and clay barred. The next day I taped up, did a polish and in some places a 2 step. That was an entire day of around 13 hrs. The next day I did a quick light wash to remove some polish dust and other dust that was on the paint from overnight, then an IPA wipe down and two coats of CarPro Lite.
The added wash step definitely added time. I never wash prior to a coating. I will just use a panel wipe (not IPA) to pick up any light dust.
IÂ’m trying to decide if I should polish my wifeÂ’s new SUV before applying some CarPro lite. I will definitely do the decon stage but it doesnÂ’t fit well in the garage and juggling the sun is difficult. She also needs access to her car often for work so itÂ’s hard for me to block a full couple days to do the process and if IÂ’m doing it outside with her car I might only get a couple hrs either side of the day where the sun can be avoided so it might take me a few weeks to complete it juggling all of that... as well as having to wash it before I start each time as it lives outside.
You should not even be "trying" to decide. Just do it lol. Go around with Essence and follow up with CQ Lite. Essence will save you the panel wipe process but as a sanity check it would not hurt to pick up any light dust before laying down the coating. And you don't have to put 2 coats. One is fine.
Makes me feel better IÂ’m not the only one taking 2 hrs haha although your 2 hrs is with UK and mine Lite. I was the same as you and negated the ease of use advantage as I was afraid of high spots too. I think I probably wiped too much and installed a few un-needed defects back into the paint.
People overthink high spots too much that they end up with them. As I mentioned a high spot is not the end of the world. It is an easy fix.
I can keep it in a garage but it still gets a bit dusty. On day 2 when I polished I would wipe down each panel with a lot of QD, (should prob get a good waterless wash for this) then hit it with Eraser to try kill any polymers the QD put on the panel, then polish. I spent a day cleaning the garage out before the detail and the car still collects dust over night.
Get yourself some Eraser pr something equivalent. They have better lubrication and you won't need to wash or use a QD.
Again we need photos lol.
Also Corey gave the thumbs up on using EcH20 on a coated surface without affecting the coating. He said he never heard of EcH20 impacting a coating negatively.
