The Guz
- Jun 17, 2013
- 8,796
- 75
Mike,
Thanks for all of your helpful info on water stains. I recently purchsed a used 2011 BMW with Space Grey paint. The previous owner kept the car outside for most of it's life. The car has a lot of mirco etching water stains, definitely type II. My initial first attempt at paint correction was with a Flex XC 3401 using Lake Country Hydro Blue cutting pad and Meguiars 101 followed by Meg's 205 with Lake Country Hydro Tangerine pad. This took a good deal of the sting out of the etchings but, did not take all of the micro pitting out of the finish.
Would you recommend continued multiple passes with the combo I listed or would you recommend a slightly more aggressive pad/compound combo? I also have a rotary with a few whool pad options but, really want to use that as a last resort.
I'd greatly appreciate some direction/recommendation. I will try to snap some pictures and get them uploaded for reference this evening. THANKS!
I had the same thing on this Blazer I polished out recently. After a couple of test spots, I knew the water spots were not going to come out and rather than making things worse, I made the decision that preservation of the clear coat was more important than a few water spots that were only visible in the right light and angle.
2019 Blazer RS AWD
