Curious how you all are dealing with bird bombs on ceramic coated vehicles. I've got an approximately one year old coat of Adam's Graphene (non-Advanced) on my Acura RDX. It's been maintained with regular washings, toppers, etc. It's been great EXCEPT for bird bomb etching. Yesterday, my car got obliterated by bird bombs at work. It then sat in the 95 degree afternoon sun and baked in. When I got home, I cleaned it up but everywhere there was a speck of bird stuff, it left a crater behind. The surface contaminants cleaned up easily, but there is definitely visible damage left behind in each spot. It looks like the typical water spot damage but not as widespread.
Frustrated, I did some testing with the iBrid Nano, a 2" Rupes blue foam pad and 3D One. It diminished the damage but it is definitely still visible. The next step would obviously be to go more aggressive on the pad/compound combination. Unfortunately, this was not one or two big spots. It was splattered in probably 30 different spots and each spot left damage. I'm assuming this is through the coating into the clear coat. That's making cleaning this up more difficult, presumably, as I'm having to cut through the coating into the clear. That also means I'm having to chase each spot with a finer polish and then of course top off the coating. What a pain in the you know what.
Before I was using a coating, I never had these issues with bird bombs. Of course, they would cause some damage, but I feel they were easier to fix. An argument could be made that this is still saving my clear coat from initial damage, but when I have to compound the coating off to remove the craters, that benefit is negated as I'm then definitely going down into the clear.
By the time I would go around the car and fix every spot, I'd be looking at having to re-coat the whole thing. The other option is to remove the coating from the whole car and switch to a durable sealant and keep it topped off with ceramic booster type products. I don't love either option because they both involve a lot of work with a machine and compound. Most of the car does not need machine polishing, but I can't leave it like this.
What would you do if you were in my shoes? Is there a specific product or something else I could try on the craters before having to two step the whole car? I'm making the assumption a two step would be necessary even on areas that are not affected in order to effectively remove the coating if that's the route I went.
