Just to tag on...
I have a Mercedes-Benz coming up that has the factory Ceramiclear finish plus it's black and all swirled out.
Have pictures and will get to them as I can...
Do you guys put these live broadcasts on you tube:buffing:
Yes, at least some of them but just to note they work equally well on any paint system I've worked on.
I've invited Ken to bring his car to Autogeek for a Thursday Night Live Broadcast in February, it has a Ceramiclear finish, (I checked the paint code), and is in need of a little TLC
Just tried Menzerna SF4000 with BuffnShine White Pad on my ceramiclear 07 Benz, one pass and I was able to remove about 99% of swirls. The deeper random scratches (RIDS) are still present. Might need to get more aggressive ?
Unless it's a show car where you're being judged on paint perfection, 99% is pretty darn good. Chasing that last % just abrades away 99% of your perfectly good clearcoat.
Which B&S white did you use? I'm guessing the euro foam, but they have 3 white pads depending on size. One is a heavy cut, one is a fine polishing pad, and the euro foam is supposed to be right around the cut of the green open cell pad, maybe a little more aggressive.
If you used the euro foam, did you happen to compare it to the green open cell?
Is the live show this Thursday?
Hello-
I was approached by my boss to do her 07 MB S Class with C040 paint.
It has some light scratches on the hood and oxidation as its an unmaintained DD. Will something like BFTPS on a white pad on a GG6 clean it up?
Im not aiming for 90% but I do want to make it look nice
thank you
This was my first job with ceramic clear. This is a Mercedes benz C class imported from Germany.Client told me car have a ceramic clear & Car was buffed by some body else before I detail it. As you guise told I have used foam pad with Meguiar's Dual action polish but it didn't work out so I moved ahead and used wool pad with meguiar's Diamond cut on a small portion. It worked great. I am also uploading a before after image of car's trunk-lid. I don't know weather I did right or wrong but client liked the car. Was there anything else that I can do?
