Yes it is on its way to us.
DARK HORSE said:Very cool!
I've heard that cerium oxide is really the only way to lessen or polish scratches from Glass. Ron (or anyone else), have you ever used cerium oxide to polish glass before?
Very cool!
Very cool!
I have not used it personally, but I've seen it used in a glass shop and it is messy to say the least.
Mike Phillips said:Glass Polishing is VERY MESSY
All the glass polishes I've used are water based and best results are achieved when you use a rotary buffer. Rotary buffers tend to throw splatter dots via inertia with any liquid, especially if you over use the product but it's even more of a problem with a very liquid product and that applies to glass polishes.
One of the reasons is that since glass polishes are water based and rotary buffers generate heat, the water evaporates fairly quickly while you still have good abrasives still on the glass. To get more use out of the abrasives I mist on some water and continue buffing and the addition of the water re-liquefies the polish but also causes splatter dots to sling off the glass polishing pads and discs.
Take my word for it, if you ever do any glass polishing with a rotary buffer you want and need to cover all adjacent panels or you'll be wiping abrasive glass polish off all these surfaces when you're finished.
Soft Autogeek Cover Up Towels with painters tape used to cover and protect the paint
You can warp the glass if you don't know what you are doing.
It was my understanding that the Diamondite glass polish is CO, according to something Mike Phillips said recently, but he also said it's out of stock...I'm not sure which one he was referring to exactly.
Buffing out scratches in glass is time-consuming and just a tick difficult because you do have to push pretty hard with the rotary buffer, you certainly don't let the glass polishing pad "glide" over the surface.
The Resurfacing Creme uses Cerium Oxide and it is out of stock.
:xyxthumbs:
I did work it with firm pressure, but used the breakdown of the Creme as my indicator of when to stop. Hindsight, I should have misted over and over again to extend the process as long as possible. I obviously didn't go long enough.
Hey Meghan how about Car Pro's Fixer Polish? Any chance its on it way too.
Also, since you've done some glass polishing, can you share your experience on whether it's messy or not?
It's in the same shipment, we should have them both in less then a week if customs is nice to us!rops:
