Chemical LSP removal other than Griot's Paint Prep?
Wouldn't just an IPA wash work? I'm thinking if all it is that you want off is a wax layer.
I don't think he was asking for a non abrasive polish either or claybar recommendations. Griot's Garage has a liquid spray on Paint Prep LSP remover and he's looking for something like that. Carpro Eraser recommendation 'may' do the trick. It is designed/intended to remove the polishing oils for a pre LSP smooth surface and wax removal may just happen to remove the wax too. Blackfire Paint Prep is a new product that may be spot on for your needs but I would read more into just to be on the safe side. Also a lot of people strip while washing using Chemical Guys Citrus Red a little more concentrated then usual or add a couple ounces of all purpose cleaner* to there maintenance wash soap.
*I know Pinnacle All Purpose and I think Blackfire lists that as one of its uses. SO I would just be careful/research which All Purpose Cleaner is safe for that because there could be plenty of unique formulas that aren't great for paint.
^this. Thank you for your tips.
Use Trix.
Kill 2 birds with one stone.
I like Iron X, I like Tar X, I don't like Trix. And also, this would be quite expensive solution too.
Duragloss squeaky clean.
Thanks
anyway, nothing is available here to, so I will import a few bottles of Paint Prep probably from our neighbors.
