QUICK QUESTION: What is the real difference between the LC Black and LC Blue pads?
I think this may work well:
Orange pads - 4
White pads - 4
Blue/Red pads - 2
For a truck my size I am wondering if I would need more though (like 6-6-2)
I have a boatload of both Black and Blue LC Pads on hand, and to tell the honest truth, I never used any of them! LOL But I have opened a couple packages, and it is hard to determine the softer of the two, they are that close IMO. Either would be good for applying sealants-waxes.
Me, I've always been a guy who likes getting more intimate when laying down an LSP, and there's a number of reasons for such. 1. By the time I yank out DA, Pads, Ext Cords, etc, I can have a coat of any wax or sealant laid down on the vehicle.
2 All I have for clean up, and put away, is an Applicator Pad, whether Foam, or MF.
3. By being able to more carefully apply the LSP, I'm not "digging out" powdery residues from every crack, seam, joint for the next 5 weeks. "I" put the product "where" I want it, and avoid these headaches seen later on.
Now, if I was a pro, or waxing a 40' Motorhome, sure, you bet I'll be wanting to machine apply a wax-sealant, but for my little shitbox daily driver, or other average sized cars, or even trucks, no thanks.
Although the Blue-Black-Red Pads are said to have no cut, trust that if you use Polishes, or more aggressive Liquid Compounds with them, you will get some degree of paint correction, just not as optimum-fast with a more aggressive Pad like Orange or Yellow LC. Meaning, they can be used in a pinch to correct on fairly pristine vehicles to Amp Gloss, and Shine. (and to remove ever so slight wash induced swirling)
My experiences with LC Pads so far have been that the 5.5" white Flat Pads are very good, they are durable, provided one doesn't run these pads flat out on high speed, and tries doing an entire vehicle with just one Pad. Overheating a pad is a sure way to destroy a Pad in short order. They aren't cheap.
But the White Flat LC Pads I have found, are quite versatile, and a very good Pad to have a good quantity of. 6-8 of these would not be a bad quantity to initially have on hand, and replace as time goes by.
I've found that with let's say the Wolfgang Trio of correction products, Uber, TSR, and Finishing Glaze, the White Pads can be used to excellent effect with all 3. The White Pads can be again used to great end results with other products, like Menzerna SF-4000/SF4500.
Final little tidbit of advice. Do buy yourself a good Pad Cleaner formula. WG, Pinnacle, Blackfire, XMT are all very good. They clean better IMO than many off the shelf APC products, will get the Pads very clean without tons of suds, and effort.
With Pads, and Backing Plates, also grab a 5 pack of the Fiber Backing Plate Washers. You'll be glad you have them on hand down the road.
