chrome exhaust detail
Mr M5
What products and tools are recommended to do this?
recommend mothers polishes from any local parts store (chrome and mag polish)
Doesn't get any better than this:
How To Clean Exhaust Tips by Machine with Wolfgang Metal Polishes
Here's the stainless steel exhaust tips on Max's AMG, not the black exhaust film building up...
The easy way to polish metal
Here's the fast and easy way to remove the black exhaust film using a Drill, the Bufferstick, a few microfiber bonnets and Wolfgang Concours Aluminum Finishing Polish.
Microfiber Bonnets
Microfiber bonnets area available in different colors so that you can dedicate them for specific products and/or procedures. To apply the Wolfgang Aluminum Concours Polish I've placed a blue microfiber bonnet over the foam head of the Bufferstick.
The black foam used for the Bufferstick is fairly aggressive and can be used by itself. The benefit to using the bonnet is the microfiber bonnet protects the foam head on the Bufferstick so the foam doesn't get chewed up from use. Then, after you're finished with your polishing project you can wash the microfiber bonnets and re-use them. This saves the foam head on the Bufferstick and saves you money.
Tape-off and protect
Because the exhaust tips are surrounded by plastic trim and clearcoated body panels, it's a good idea to place some 3M Masking Tape over these areas to protect them from splatter and also to in-case you accidentally run the spinning pad/bonnet into the trim or paint.
Stir before use
Here's how the Wolfgang Concours Aluminum Polish looks when you first remove the lid. This is normal.
Using a clean wooden stirring stick to stir the polish...
Once you have created a uniform looking consistency, the polish is ready to use...
Apply polish to bonnet
You can do this with your stir stick, a spoon or spatula or like I'm doing, simply place the bonnet into the jar of polish.
Technique Tip
While it's easy and even natural to run the drill at maximum speed by simply pulling the trigger all the way, the Bufferstick and bonnet actually work better at a medium speed. too high a speed will force inertia to cause the bonnet to sling outward and bunch up. Running the Bufferstick at a medium speed will prevent this...
Wipe to a bright mirror shine
After buffing the residue, wipe off any excess and rub the metal surface using a clean, dry microfiber towel to reveal a brilliant, clear mirror shine.
Machine Wipe
You can also place a clean, dry microfiber bonnet over the head of the Bufferstick and let the Drill wipe off any excess residue and polish the metal to a high shine.
Remove protective tape
After you've removed any excess polish, remove the tape and check out the shine!
And continued to here:
And here are the results...
Clean and shiny, like a diamond ring!
Reversible and re-usable
The microfiber bonnets are reversible and re-usable. Simply wash and dry alone or with similar metal polishing microfiber towels.
If you have a car with polished exhaust tips or any component of your car is polished metal, then here's the fast easy way to clean and polish metal while taking all the work out of it...
On Autogeek.net
Wolfgang MetallWerk Polishes
There are 3 grades of metal polish to choose from but you always want to follow more aggressive steps with the less aggressive polishes and always finish out using the Concours Aluminum Polish.
Wolfgang MetallWerk™ Concours Aluminum Polish
Wolfgang MetallWerk™ Fine Aluminum Polish
Wolfgang MetallWerk™ Aluminum Compound
Buffersticks for use with any drill
Bufferstick Wheel Polishing Tool & Microfiber Bonnets
Red Bufferstick Wheel Buffing Tool
Powerful Cordless Makita Drill and Driver
Makita 18V LXT Lithium-Ion Cordless 1/2 inch Driver Drill Kit
The Makita Drill Kit includes,
1 each Makita 18V LXT Lithium-Ion Cordless 1/2 inch Driver Drill
2 each 18V LXT Lithium-Ion Battery (BL1830)
30-Minute Rapid Optimum Charger (DC18RA)
Tool Case (824953-7)
Tool Belt Clip (346034-2)
Really great response...I did not have any scratches and had great luck with Borla's exhaust polish and then opti coat
