I have been doing some research on this topic but have not found a "real" answer from general AUTOGEEK members, or the pro's. I would like you guys to answer with one of the three answers below, and your opinion on why you use this method over the other.
When applying a polish or wax with a foam applicator by hand, do you use circular motions or straight lines?
1. Circles.
2. Straight Lines.
3. Shouldn't matter.
Why do you use that method over the other?
I know alot of "pro's" say to use straight lines, but what is the reason behind it? If there was something under your pad, ie. "grit" then it wouldn't matter what direction your pad is moving, as you are going to scratch your surface, correct?
Thanks in advance!
1. Circles.
2. Straight Lines.
Thanks in advance!
