Clay Applicator Pad
Interesting, I'd be worried about the clay not having enough lube and hits a dry spot and causes marring/sticks to paint. Hell it can happen by hand, by machine would be worse.
I never used it, never even thought of using it. But Surfer is right about marrings.
If you do buy it and use it, please post a review on that product.
I tried our Polishing Pal with clay attachment when it was first released. Two issues were immediately clear.
1. Tactile Feel --- you lose the ability for the clay to talk to you. Thus the studdering and shudders are not caught.
2. Grinding --- in certain areas it is as if you are using the clay to hard and grinding it as little pieces of clay attach to paint.
I have used alot on large flat surfaces..ie trucks and toppers.
The negative is the amount of clay you use. The positive is the foam pad will hold lubrication for a long time.
why sell it then? that's not cool.:confused:
People still want it, and well AG is the business of making money :D . If its going to make them money.
As for the polishing pal, its easy enough to clay by hand, You can kneed the clay often, and really feel the paint as you go.
Although it may seem user freindly and fun to play with you loose that important connection with the paint. I know when i clay my finger tips hang over a little so i can get a feel when a section is done, just my way of makig sure i havent missed anything.
too true! lol....
to each his own, eh?
Mery Christmas!!!
LTIm the MAN
I WANT ONE.
I will just use DP 4 in 1 wash to lube if I have to. Machine claying in FLA would get me out of the heat alot faster....
Im very interested in this.
-Ryan
ryandamartini said:
I WANT ONE.
-Ryan
Ryan-
Doesn't what Kllr said about scratching worry you some tho? Worries me! lol /but what doesn't? hee hee
I used one of these applicators, but I found that it allowed the clay to "worm out" and end up on the floor. There seemed no good way to make the clay stick in the recessed area and it resulted in using a lot more clay as I had to replace several pieces of clay that had fallen to the floor. I ended claying by hand and will continue to do so.
ltoman said:
Ryan-
I wouldnt be worried about the PAD. He was talking about the polishin pal scratching. I dont see foam on top of lube scratching any finish.
well first I only get to give my input, not is a position to pick or discontinue a product. Second, it is only my opinion, others love it. Most still use them as a hand polisher with nice results. Mine ended up in the kitchen, and wife uses them on sink, shower, and other areas where hand scrubbing is needed.
Help please..
Here is a question, I have been claying for hours. I did the hood of the car and I spent at least 30min on the hood. Yet every time I go back and give it a quick pass with the clay bar it still grabs? Is it sopposed to do that? Does that mean that I haven't clayed properly?
Sorry to hi jack, but it is kinda related :D oh and I know what you guys mean about the feel of it. Fist time claying and I can defenetly feel the clay bar grab every time and every inperfection of the paint...I think I'm going to stick with claying by hand better feel I think.
it isn't supposed to grab anymore once you've gotten it off...you aren't using it without lube, are you nica?
i just did our wagon, and once it was off, it was off. and it was bad. maybe scott or someone else will know....
good luck dude!!
:Picture: ???? Lauren
still, scratching is scratching...
Like I said, to each his own! ;)
Merry Christmas!
Lauren
sorry, killer!!
oops...
didn't mean to cause a fuss!
maybe i can get my husband to get one and he can clean the shower, etc with it!!! LOL he does sometimes any way.
sorry.....:o :o :o :o
Merry Christmas, dude!!
Lauren:p
Wow....supprised by the feedback on this question but I guess it brings up some definate points to think about. Thank you all for the input. Merry Christmas!
Merry Christmas!
Lauren
the point is that the FOAM will not scratch.. Just have it lubed really well. It would be another method, probably used on cars that need light claying. On heavily contaminated cars, I would still use hand methods.
If you kept the pad lubed and used a good car wash, I dont see any scratches happening unless your forcing the c through the sheetmetal for some reason....
ummm, now you've lost me. I am not that knowledgeable, i am afraid, to discuss this in such detail.
you win.;)
In the meantime, claying by hand works for me and to each his own. America!:grouphug: :grouphug:
