budman3
- Mar 3, 2006
- 1,744
What didnt you like about the DP? I used it recently and thought it worked great, actually less agressive then I anticipated.
The DP clay is just Auto Magic clay with the DP name on it. The same gray clay can also be found as the Chemical Guys clay, Sonus, Poorboy's, etc.
The Clay Magic is the only clay that carries the AM name so that is why some may like the CM blue over the gray. There is plenty of technology (and plenty of money) that Auto Magic can use and reformulate their clay into something that doesn't crumble or break apart... something like the Riccardo clay available in Canada or the old yellow Erazer clay bars. But they aren't doing that ... for those of us that had the privelage to use the yellow clay makes any other clay substandard.
Here is a picture of my issues with CM blue:
Right out of the package it crumbles and breaks apart. It smells like a crayon and sticks to your hands. Adding some lube does help but if you add too much it'll start to degrade and crumble.
