Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Are there any clay bars out there / available that will take out surface contaminants -- yet fine enough that polishing will not be necessary?
The finest clay I have used that is still effective is Pinnacle. It is the most likely clay to not leave marring behind. Won’t always be the case tho. Try a test spot.
Shall I say it is the most gentle clay product on the market..
Pinnacle?s Ultra Poly Clay is the single finest clay composition available today. Use auto Detailing clay to deep clean car paint, glass and chrome.
I've not only had good luck with the Pinnacle Ultra Poly Clay - I've also shared a number of car detail projects I've done personally where I chose this clay just because I believe it will give me the best chance to clay the car, remove the contaminants and keep marring to a minimum.
BUT - my RULE is - IF I'm going to clay a car - I"m also going to do at least one machine polishing step.
Here's one example, a full write-up too, something you simply cannot find easily anywhere else, any longer.
See post #4
Review: Pinnacle Jeweling Wax - 2014 Maserati GT Sport detailed by Mike Phillips
