Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Mike,
I have never clay barred before, so for a first timer, do you recommend Nanoskin system or clay bar system?
This is just my opinion based upon experience.
If you're NEW to detailing in general and specifically you're NEW to machine polishing then I would recommend using a very safe ultra fine clay like the Pinnacle Ultra Poly Clay.
First... you need to learn how to walk before you can run and by this I mean you need to learn and acquire great "hand skills" to be a well rounded detailer. Even if you're just an enthusiast detailer.
Second... and again, in my opinion, a safe, ultra fine detailing clay is safer for new people than any of the more advanced tools like Nanoskin products.
I could go into greater detail but I'll just leave it at that...
Yea, I can't see myself doing the DA thing either. I'm 48 and have done all my own detailing by hand.
Seen too many screw ups from people not knowing what they're doing.
Don't wanna be that guy. Thanks for your help.
Totally agree. I've made a career out of showing people how not to screw up.
Fact of the matter is when it comes to creating the best results, not very good results but "best results" a machine is required. I explain why in my first and second how-to book in the first chapter called,
Car Paint Overview
This chapter shared the history of CAR PAINT. And in this chapter I explain the differences in the two types of car paint we've had in the history of the automobile and then tie the changes to why machine polishing has become so popular and so easy and safe.
It all starts with head knowledge, not a can of wax or a buffer and that's what my books give you.
The Complete Guide to a Show Car Shine Paperback Book
If you read this entire book from cover to cover you will know more than most detailers because most detailers are self-taught. You'll also know more than most people about the general topic of car detailing and specifically about paint care including machine compounding, polishing and sealing the paint.
I was using the traditional clay bar up until recently. I had purchased a nanoskin mitt from Chemical Guys medium grade and its fantastic. Claying a car now with the mitt is the way to go. I can clay a medium size car in 15 minutes all while washing the car at the same time. The car shampoo acts as a super lubercant and works amazing.
Traditional clay bars are a PITA and takes far longer to complete. Drop the clay bar and your done. Should be thrown away immediately. Drop the nanoskin mitt, just rinse it off with the hose and your good too go. The nanoskin mitt costs 60 dollars and I can clay around 70 vehicles with it.
The clay mitt is the way to go and as long as you have good lubercation, marring shouldn't be an issue. I have also been using my Auto Geek foam gun prior to my nanoskin clay mitt for even more lubercation and break dirt down.
Good summary and approach to washing and mechanically decontaminating a car's paint at the same time.
This is the approach I teach in my detailing boot camp classes for doing production detailing.
As far as marring paint goes... I use BLACK paint as the true test of any paint related product.
Here's marring from a Nanoskin towel. I know because I washed this Tahoe and detailed it and used a Nanoskin Towel to decontaminate the paint.
The scratches you see all over the hood were there before I washed the car. That's because this Tahoe is abused and neglected. The marring was caused when I rubbed the Nanoskin towel over the paint.
Two things...
1. In this thread and every post I've ever made I say the same thing...
If you're going to use ANYTHING to mechanically decontaminate paint, this includes clay, then my practice is to have already made plans to do at least ONE MACHINE POLISHING STEP to remove any marring. Seen or unseen.
2. I use black paint because it SHOWS everything. Something else I always share in the forum world is that if marring is happening to clearcoated black paint it's likely happening to ANY COLOR of paint it's just your eyes can't easily see defects on lighter colors.
Make sense?
If removing all contaminates is important why was iron removal left out?
Iron X then clay?
Iron X is an optional step.
I recommend using an iron remover the first time you detail your own car as a type of insurance.
Again... I've posted this numerous times on this forum and here it is again...
Iron X is like car insurance. You want to use it but you actually don't want it to work.
By this I mean it's better to spray your car's paint down with Iron X and see NOTHING because that means your paint was NOT contaminated with Iron. The only way to find out though is to actually spend the money and invest your time into doing the Iron X step.
IF you do see the bleeding effect then you can take comfort that although your paint was contaminated and Iron particles were doing unseen DAMAGE to the paint, now you've removed it.
See how it works?
As for using Iron X in a detailing business the stuff isn't cheap so if you're going to use it you either have to,
A: Build it into your price.
B: Offer it as a menu item for an extra charge. To do it this way "you" as a professional detailer have to know how to educate your customer so they see the value. That's what this forum is about... education.
Hope all of the above helps...B: Offer it as a menu item for an extra charge. To do it this way "you" as a professional detailer have to know how to educate your customer so they see the value. That's what this forum is about... education.
:dblthumb2:
