Clay
Irishwoodchuck
Just bought a black 2011 Camry and am new to claying and looking for some advice as well as product recommendations. I would really like that shiny showroom finish. I do not want to do it wrong and wreck the paint.
What type of clay?
How often to re clay?
How to Clay the process?
Do you use any other products after you use the rubbing compound?
Forget clay. Get the nanoskin decontamination sponge combo pack AG sells and never have to clay again. I clay my personal vehicle every 3-6 months, depending on how it feels. As far as the process, spray clay lubricant, run sponge over a section at a time, wipe dry with microfiber. Repeat as need until you don't feel any contaminants on paint.
What type of clay?
First thing I'd do is read up a lot, then do work. If you're thinking of using "rubbing compound" then I suggest really reading mikes threads and learning how to detail from start to finish.
it amazes me that there is so soooo muchhh info on everrythhinnggg you need to know about clay on the internet, yet ppl still ask.. there are probably over 1000 threads online from various detailing forums and youtube videos to explain this.. crazy lol
adams clay bar, its new, cheap, you can get 4 pieces out of it and its really sticky and can take on any job.
Saver your self money get the NANOSKIN Autoscrub Fine Grade Wash Mitt. faster than clay and if you drop it your not out $25 and will save you lots of time. You can do up to 45 cars with it.
What type of clay?
Pick up one of Mike's books and read through it. There is so much valueable information in it to help you get a good understanding on how to properly execute each step of the detailing process.
Autogeek Gear
Welcome to AGO. :)
I went with the DP clay kit and read up on it a but. But I still have a question.
The Process as I understand it is that you get the car clean as you normally would. Then Dry it as normal, once cool and dry then you start working the clay in small sections of the vehicle at a time until it is like glass until you have completed the whole vehicle. My question is after you have done this do you then re apply your rubbing compound before you put the paint seal on?
Ben
Be sure to wash vehicle after claying. :buffing:
Ben
Hi Ben...
I'm not sure that I understand your definition of a "rubbing compound".
Please advise. Thanks.
I think that may be precisely the problem... there is sooo much information on it, and the fact that it's not necessarily the same information. As easy as it is to find good information, it's just as easy (if not easier) to find bad information.
