I know that the spray detailer like final inspection or the types are a bit expensive, but are you claying your car that often that you use a lot of it?
I clayed a giant 2002 Caddy DTS and my 2003 Ranger FX4 and still have enough to probably do my brother's '05 GTi without a problem. That's about 5 bucks a car (on the expensive side) and I was pretty liberal with the lubricant.
ONR is probably the best economical clay lube when doing a lot of cars, a 32 oz bottle costs 16 bucks, and makes 16 gallons of clay lube if mixed 2:128. So thats an estimated 4 cents per car if used while the car is still wet, and about 10 cents a car if used while the car is dry.
You can mix it stronger say 6 oz/gal and it would still only cost about 12-30 cents a car depending on the method.
Heh. I was looking at it from the weekend detailer-as-a-hobby guy's eyes. For me, 5 bucks a car isn't bad if I'm only going to be claying the car occasionally. For those that are doing it in volume/for a living... I can see your point.
Would car wash soap work just as good?
