Clean & Extend Life of Detailing Clay w/Blackfire
Nick McKees37
McKee's 37 Product Support
One of the most frequent questions people have regarding detailing clay is how often can you use it? Quite a few factors come in to play, such as vehicle condition, size of clay bar, etc. If you clay a vehicle that's been sitting outside for fifteen years and has never been clayed, you can count on using at least one 50-100 gram clay bar. That's if you want to ensure you don't reintroduce any embedded contaminants in the clay back onto the paint, possibly scratching or marring the finish. If you're claying your vehicle, you're on the right track to silky smooth paint and the last thing you want to do is not work smart and damage the finish that you're trying to inject some life in to.
I'm a big fan of Pinnacle's XMT Speed Clay because it's large (over 200 grams!) and very easy to use. For the size and the quality of the bar, it's a heck of a bargain at 20 bucks. The XMT Speed Clay is large enough to break in to three or four smaller pieces so you can store the rest for later. This enables you to maximize your investment and get the most out of your clay bar. But what if you want to take it a step farther? We all like to get the most out of our detailing supplies and thanks to one product in particular, this is certainly possible with your detailing clay.
Blackfire Clay Cleaner & Extender takes working clean to the next level. Even after you fold and re knead a clay bar several times, there is still a good chance you will re-introduce embedded contaminants in the clay bar back onto the vehicle's finish. With Blackfire Clay Cleaner & Extender, you can now clean the majority of the contaminants in your clay bar to ensure you don't scratch or mar the finish in the future.
First you want to make sure you're working over a bucket or sink. Spray the clay bar with the Blackfire Clay Cleaner & Extender.
Blackfire Clay Cleaner & Extender features special surfactants that will effectively clean the clay bar, but will not dry it out. Rub your fingers over the clay bar. This will help loosen any contaminants in the bar.
Blackfire Clay Cleaner & Extender starts working immediately. Now can you imagine having all that dirt and gunk trapped in the clay bar before storing it for future use?
Rinse the bar with stream of water after agitating it with your fingers. Another option is to place the clay in a bucket of water.
Blackfire Clay Cleaner & Extender leaves detailing clay looking new and ready for the next job!
As you normally would, spray the clay bar with the proper lubricant before storing it for future use.
Whether you're a professional detailer with pounds of detailing in your arsenal or just an enthusiast that likes to get the most out of your products, Blackfire Clay Cleaner & Extender takes detailing clay to next level.
:dblthumb2:
Another thing to think about buying! Just a thought though. Seems this product would have to be used after each panel otherwise if you knead it before hand as your claying the car then it's in there for good.
You can do it after every panel, or after claying the really dirty panels (hood, roof, etc). It will clean about 95%-98% of the dirt and debris from the clay and only takes a couple seconds if you have a sink or bucket handy. :props:
Great review Nick:props:
Thank you for bringing my attention to a product that I never would've know even existed. Next batch of orders I'll probably pick this one up.
How well does it work to remove tar?
I use clay a fair amount to remove tar and it pretty much destroys my clay.
Will it remove gritty dirt from the bar?
It will remove 95%-98% of the contamination from the clay bar. If you notice any obvious chunks of grit, you can simply remove those using your finger nails.
From my experience it removes tar fairly well. :props:
Very neat, I haven't tried that product yet! And that was some nasty clay, hope that wasn't from my car!
Great review Nick. This is a product I really want to try !!!
Thanks for the post, Nick. But, am I the only only one that would rather just buy new clay? I am not a professional detailer, more the enthusiast, so that may be the difference. Just too much work, more expense, etc. Not criticising if it works for you.
It takes so little cleaner that if you have multiple clay bars, or if you're a professional detailer with pounds of clay, a couple bucks for a 16oz bottle of cleaner is well worth it. It's a similar concept to cleaning your pads after each use. Yes, the clay is going to wear out eventually or become heavily soiled, but at least this product helps extend the life by thoroughly cleaning the bar after each use. :props:
