Clean roof material - Mazda 3
ChaoscripT
Hi,
In my car the roof material get black,
With which product can I clean it please?
Regards.
You mean the headliner? If it is, you can just use an APC and gently wipe it with a microfiber towel. Refrain from getting the headliner wet as it will most likely sag.
^ thats it :) just spray some APC on a towel and wipe (no rubbing)- that material on the 3 is really sensitive.
OK,
Which dilution to APC ?
What about if it's not clean this ?
Can I spray direct to the roof then draw itwith Dry/wet vaccum ?
Regards.
Your the one working on the car so you are the best judge of the condition of the material and how to treat it. Just like Mike says start with the least aggressive and then step it up from their.
Do not spray directly on to the headliner. Sometimes if too much cleaning products are used a headliner can start to droop shortly after it dries.
If you want more specific advice or if you are having trouble describing it please post a picture.
