:iagree:Wash your body including your feet.I always clean tires, wheels, and wells, seperate and before i do the paint. They also get a seperate bucket. I have a wheel brush, wheel woolie, tire brush and well brush. The wheel and tires take me just as long to clean as the paint does in whole but, they are very important! I use griots or adams wheel cleaners and tire cleaners. It really helps the dressing to stick and stay.
So I inspected my tires. They do look kinda streaky. Thanks for giving me another part of my car to tweak out on. My wife will be thrilled when I explain it's gonna take a little longer cuz I have to make sure my tires are clean.
Car soap is not enough to clean tires. You need something that can cut grease, and car soap can't.
Simple solution, use dish soap. Better solution, use an APC or degreaser. Best solution, use a cleaner designed for tires.
As a pro detailer, I simply use a degreaser.
I agree with everything you said. If I got my tires perfectly clean and decided I wanted to maintain them by scrubbing them 1-2 times per week with the tuff shine tire brush and either my rinseless wash (n-914) or my traditional soap (optimum car wash) would it be possible to effectively keep a tire clean?
Also, which is more capable of actually cleaning a tire? A car soap like optimum car wash or a rinseless wash like D114 or N-914?
Neither products are good for cleaning tires. When you apply a tire dressing, you are adding a protective product on the rubber. Both of these cleaning products are Ph neutral and are designed not to remove protective products such as wax or dressing. In order to clean the tire you need a degreasing product, so as I said, dish soap, apc, degreaser or tire specific cleaner are the only real solutions you have.
With that said, if you clean you tire twice a week, there is no need to scrub them everytime. Once you have a protective product on them, simply wash them with your normal car soap until you seen the need to do a deep cleaning and re-apply the protective product. So when they start turning brown, or you see dirt you cannot remove with the car soap, that is when you want to scrub them with a brush and degreaser.
I use D143 to clean the tires once the dressing starts to wear down and needs reapplication. When the dressing is still good, I just use regular shampoo with my wheel mitt to clean away any light dirt.
Believe it or not, About half of my customers specifically ask me not to use ANY dressing on their tires. Granted, most of the cars I work on are classic cars and alot of the guys that hire me are purists who like a "clean" undressed tire on their unrestored cars
That's like taking a shower and washing your body with soap and a wash cloth, but not your feet because the run off soap will clean them..it's called toe jams.
